A Spotify deep link is a link that opens a track, album, playlist, artist, or podcast directly in the Spotify app instead of the web player.
If you are an artist, podcaster, or marketer sharing Spotify links from your Instagram bio, stories, or ads, you have probably watched them open in a logged-out web player.
That is a problem, because saves, follows, and streams from a signed-in app listener are what actually feed Spotify’s algorithm.
Here is the honest answer up front: on mobile, a normal open.spotify.com link usually opens the app on its own.
It fails in specific situations, and this guide shows you why, how to fix each one, and how to force the app to open even from inside Instagram.
- A Spotify deep link opens content directly in the Spotify app, not the browser web player.
- Standard
open.spotify.comlinks already open the app on mobile through universal links and app links when the app is installed. - The
spotify:URI scheme (for examplespotify:track:ID) forces the app, but it is not clickable everywhere and breaks for people without the app. - The main reason links fail is in-app browsers, like Instagram, which trap listeners in the logged-out web player.
- A deep link tool like Linko forces the app to open, escapes Instagram’s in-app browser, and falls back to the web player if the app is missing.
What Is a Spotify Deep Link?
A deep link is any link that opens a specific place inside a mobile app.
A Spotify deep link takes a listener straight to your track, album, playlist, artist profile, or podcast inside the Spotify app, where they are already signed in.
That matters more for Spotify than for most apps.
A signed-in listener can save your song, follow your profile, and add you to a playlist in one tap, and their play counts toward your streams.
A listener stuck in the web player often cannot do any of that.
If you want the full background, see our guide on what deep linking is and how it works.
How Do You Get a Spotify Link or URI?
Before fixing anything, here is how to grab the two link types Spotify gives you.
The share link (web URL).
- In the Spotify app, tap the three dots on any track, album, playlist, artist, or podcast, then choose Share and Copy link.
- You get a URL like
https://open.spotify.com/track/TRACK_ID. This is the link you will share almost everywhere.
The Spotify URI.
- On the desktop app, right-click an item, open Share, and hold Alt on Windows or Option on Mac to reveal Copy Spotify URI.
- You get an identifier like
spotify:track:TRACK_ID, using colons and no slashes. This one opens the app directly.
For normal sharing, the open.spotify.com link is what you want, because it opens the app on mobile and still works for people who do not have it.
Spotify Deep Link Formats
Every piece of Spotify content has both a web link and a URI.
Here is how they map, straight from Spotify’s developer documentation:
| Content | Web link (opens app on mobile) | Spotify URI (forces app) |
| Track | open.spotify.com/track/ID | spotify:track:ID |
| Album | open.spotify.com/album/ID | spotify:album:ID |
| Playlist | open.spotify.com/playlist/ID | spotify:playlist:ID |
| Artist | open.spotify.com/artist/ID | spotify:artist:ID |
| Podcast episode | open.spotify.com/episode/ID | spotify:episode:ID |
| Podcast show | open.spotify.com/show/ID | spotify:show:ID |
The spotify: URI opens the app instantly on a device that has it, which is why developers use it inside their own apps.
The catch is that it is not a clickable web link, so it fails in a browser, an email, or a bio when the app is not installed.
For the difference between these link types, see our guide on deep links vs Universal Links vs App Links vs URI schemes.
Why Do Spotify Links Open in the Browser Instead of the App?
This is the real question behind most searches, so here is the straight answer.
Spotify supports universal links on iOS and app links on Android.
When someone taps an open.spotify.com link with the app installed, it normally opens the app.
Links fail to do that in three situations:
- The link is tapped inside an in-app browser, such as Instagram or TikTok, which ignores universal links.
- The listener does not have the Spotify app installed, so the link loads the web player.
- On Android, the “open supported links” setting for Spotify is turned off.
The last one you can fix in your own phone’s settings.
The first is the one that quietly costs creators the most, and you cannot fix it on your listener’s phone.
The Real Problem: In-App Browsers
When you put a Spotify link in your Instagram bio or story, tapping it opens Instagram’s own in-app browser, not Safari or Chrome, and not the Spotify app.
Your song loads in the web player, where the listener is usually logged out.
They cannot easily save the track, follow you, or add it to a playlist, and the friction means many just leave.
For an artist trying to build momentum, that is lost growth on every share.
You cannot change this with device settings, because it happens on your listener’s phone.
You fix it at the link, using a deep link that forces the Spotify app to open.
Our guide on how to get out of in-app browsers covers this problem across platforms.
How to Create a Spotify Deep Link with Linko
Linko turns a normal Spotify URL into a deep link that opens the app reliably, even from inside Instagram.
Here is how.
- In Spotify, copy the share link for your track, album, playlist, artist page, or podcast.
- Paste it into Linko and open the Advanced options.
- Enable the Deep Linking toggle. Linko detects Spotify and builds the app link for iPhone, iPad, and Android automatically.
- Click Shorten to get your deep link.
When someone taps that link, the Spotify app opens on your exact track or profile.
If the app is not installed, the link falls back to the web player, so no listener is lost.
Linko also automatically bypasses Instagram’s in-app browser restrictions, so links open directly instead of in Instagram’s limited browser.
Linko’s deep linking is available on the Business plan at $79 per month and the Agency plan, and it supports Spotify along with around 28 other platforms.
You can see how the same setup works elsewhere in our YouTube deep link and TikTok deep link guides.
Which Linko Plan Do You Need?
Deep linking, which powers both opening the Spotify app and the Instagram in-app browser escape, is available on Linko’s Business and Agency plans.
You can create a free account to set up and brand your links first, then upgrade to turn on deep linking.
See the full Linko pricing breakdown for details.
For simply opening Spotify on your own phone, you do not need a paid tool.
The device settings above are enough.
Deep linking earns its place when you are sharing to an audience whose phones you cannot control.
Bonus: Turn Your Spotify Link into a QR Code
For gig posters, merch, vinyl inserts, or album packaging, turn your Spotify link into a QR code.
Anyone who scans it lands on your track or profile in the app.
Paste your Spotify link into Linko’s free QR code generator, choose a dynamic URL QR code, add your logo, and download it.
Because it is dynamic, you can point it at a new single later without reprinting anything.
How do I make a Spotify link open in the app?
On mobile, a standard open.spotify.com link already opens the app through universal links when it is installed. To make a link that opens the app even from Instagram or TikTok, create a deep link with a tool like Linko, which forces the app to open and falls back to the web player if it is not installed.
What is a Spotify URI?
A Spotify URI is an identifier like spotify:track:ID that opens content directly in the Spotify app. It uses colons instead of slashes. It is great inside apps, but it is not a clickable web link and fails for anyone without the app, so the open.spotify.com URL is better for public sharing.
Why does my Spotify link open the web player instead of the app?
Usually because it was tapped inside an in-app browser like Instagram, or because the listener does not have the app installed. In-app browsers ignore universal links, so the track loads in the logged-out web player instead of the app.
Can I deep link to a podcast or playlist, not just a song?
Yes. Spotify supports deep links to tracks, albums, playlists, artist profiles, podcast episodes, and shows, and Linko can build a deep link for any of them.
Does opening in the app really matter for artists?
Yes. In the app, a signed-in listener can save your song, follow you, and add it to playlists in one tap, and their play counts toward your streams. In the web player, most listeners are logged out and take none of those actions, so you lose growth.
Get Your Spotify Links Opening in the App
If Spotify opens in the app on your own phone, a quick settings check is all you need.
If you share links from your Instagram bio, stories, or campaigns, a deep link is the only way to force the app to open for your audience.
Linko creates Spotify deep links that open the app, escape Instagram’s in-app browser, and fall back to the web player when needed.
Create your free Linko account and start building smart links today.
You can test shortening with the free link shortener, then upgrade when you need deep linking.
